Sponsored by:
Sponsored by:
How do you replace dash lights in a 98?
Old 10-21-2007, 06:52 AM
Cheri's Avatar
Default How do you replace dash lights in a 98?
Hi,
I have a 1998 with 145,000 miles on it. Recently the lights on the instument panel have started going out. I can see 1/2 of the dash lights, the lights for Drive, reverse, etc have gone out and the temp controls have gone out.
I can't seem to find anywhere in the manual how to replace these lights. Are they replaced with bulbs, or are fuses needed to be replaced?
Thanks,
Cheri
Old 10-21-2007, 12:58 PM
boogz's Avatar
Default RE: How do you replace dash lights in a 98?
There are bulbs that can be replaced for your instrument panel. But to be on the safe side I would check my fuses first and see if any of them has blown out. This is so that if there is a fuse problem you wont have to spend wasted money on bulbs. But if theres a blown bulb then go purchase them. The degree if difficulty when changing your bulbs in the instrument pannel is not overly difficult. But time consuming because of everything you need to unscrew, as well as taking out the old burnt out bulbs, tight spaces, etc.
Chameleon
03-17-2016 01:09 PM
lemmon_water
07-01-2015 05:18 AM
jetfire
07-03-2009 02:34 AM
Mark61
05-18-2009 08:34 PM
drickelton
07-11-2008 10:13 PM
Quick Reply: How do you replace dash lights in a 98?
