Parking Brake
Parking Brake
I have a 2000 Toyota Camry ( LE,V6).
I seem to have a sporadic problem with the parking brake. It sticks when I try to releae it. I wonder if there is anything you can suggest that will help.
Also, can you advise if I have to depress the thumb button when I
SET the parking brake, and do I release the parking brake before or after putting the car in gear?
THank you
THank you
RE: Parking Brake
Only need to press thumb button to release, not engage it.
If the car has 4-wheel disk brakes and your foot is firmly on the brake pedal when placed in gear the car should not move. Then it should not make a differance if E-brake is on or off.
If the car moves and or has rear drums it would be perhaps best to disengage the E-brake before putting trans in gear. This would prevent the shoes from shifting or trying to have the shoes retract when the brakes are applied.
What is sticking, the brake arm, brakes themselves?
RE: Parking Brake
ORIGINAL: FrankieQ2
ORIGINAL: FrankieQ2
SET the parking brake,...
ORIGINAL: FrankieQ2
...and do I release the parking brake before or after putting the car in gear?
http://www.driversedguru.com/driving...parking-brake/
1989_Camry
12-27-2015 09:21 PM
