Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Engine sputter when punching throttle
Old 04-13-2016, 10:02 AM
Samuel Jones's Avatar
Default Engine sputter when punching throttle
I am trying to troubleshoot my 1995 Toyota Camry 2.2, 4 cylinder. The engine idles fine, if you ease on the fuel it is smooth wherever you hold it. If you punch the throttle it sputters. I have installed new fuel pump and strainer, fuel filter, fuel pressure regulator, injectors seals and o-rings, cleaned throttle body, cleaned the IAC, installed new air intake sensor. If someone could give a good direction to head so I can eliminate this throttle punching sputter issue, it would be greatly appreciated.
Old 04-13-2016, 04:45 PM
Check ignition system.
chrisdupe
08-05-2009 12:30 AM
RobK
02-16-2008 04:04 PM
bassposse
09-06-2007 12:18 AM
plopband
12-08-2006 09:25 PM
marc780
04-10-2006 06:22 PM
Quick Reply: Engine sputter when punching throttle
