Door panel separation?
Old May 23, 2013 | 09:30 PM
jridgerunner's Avatar
Default Door panel separation?
I just bought 98 camry and it has the hideous door panel separation under window switches. Can someone please point me in the right direction to repair this. Thanks.
Old May 24, 2013 | 09:47 AM
If you can get between the surface panel and substrate use a vinyl to cardboard or vinyl top adhesive.
Scrape off anything loose that might impede the adhesive to stick.
3M make sprays adhesives for vinyl and cardboard. Vinyl Super trim spray adhesive is one.
Weldwood makes an industrial landau top contact cement.
If spraying on the material will cause a mess, spray into a container and brush it on.
The box hardware stores should have a contact adhesives for these materials. Follow directions to achieve a permanent repair.
Viktor
May 17, 2012 09:11 PM
Kevin Karsky Kev
Apr 7, 2010 09:33 AM
GTScott
Feb 25, 2008 11:29 AM
cmrylovr
Jul 30, 2006 05:10 PM
mhamlin
Jan 13, 2006 09:41 PM
