Browse all: General Overview
- Toyota Camry 4th, 5th, and 6th gen How to Clean Foggy Headlights
headlight cloudy
headlight cloudy
Does anyone know of any home cleaning solutions I can use to clean by front headlight plastic covers. They are very cloudy and before I spend too much money on new ones I am willing to try something cheaper.
96 Camry
96 Camry
RE: headlight cloudy
I'm not sure how safe this is for camry headlights but I've done it with celica headlights so I'm willing to say it's probably just as safe. Get a hairdryer and set it to the hottest setting and try to see if that doesn't clear up the condensation. Just aim at the effected areas. If by cloudy you don't mean condensation, you should be able to open up the headlights and just clean them with your hands. This will take longer and as a camry owner i should know this but since I just started getting into it, i don't but you MAY have to take off the front bumper to get the headlights off. I would probably just invest in new headlights because this haze in your headlights will just keep coming back if the headlight has bad seals.
My friend's mustang had the same problem. The headlights turned **** yellow after so much use. What he did was he wetsanded them down with 400grit, then 1500grit, and finaly 2000grit and then he buffed them and put some wax. I can say that he saved himself about $200 bucks.
ORIGINAL: Viktor
