Old Aug 26, 2015, 01:06 PM
How-Tos on this Topic
Browse all: Exterior Guides
Print Wikipost
Removing trunk badges?
Old Jan 21, 2007 | 12:28 PM
jrschultz's Avatar
Default Removing trunk badges?
I was thinking of deleting all of the emblems off of my trunk. I was wondering if they are just held on by double sided sticky tape, or if removing them would leave holes in the trunk.
Old Jan 23, 2007 | 01:07 AM
jrschultz's Avatar
Default RE: Removing trunk badges?
Soooooooooooooo...Nobody knows?
Old Feb 16, 2007 | 01:20 AM
Ohmare_Q's Avatar
They have holes, but it's nothing a litlle bondo can't cover up, LOL!
Old Feb 21, 2007 | 07:56 PM
lavalleemike's Avatar
Very small holes..
Old May 11, 2007 | 11:44 PM
mp99121's Avatar
The middle Toyota badge has two small holes and double sided tape. The others just have the tape and are easy to remove. I just put some superglue (sounds really dodgy) in the holes and then painted them with touch-up paint and you can hardly see where they were.
Old May 12, 2007 | 06:25 PM
camry313's Avatar
small holes as i found it while i was thinking about replacing them with new 1's\ they actully look good on the car rather removing them ... but try & if u don't like it ... put them back
Old May 21, 2007 | 09:04 PM
j kellz's Avatar
on the 05s the camry and toyota badges come off with a heat gun and some fishing line then u just buff the rest out. i left the middle toyota symbol on until i shave and flatten the entire back. but the first two take less than 20 min to do
Old May 25, 2007 | 04:30 PM
gslrider's Avatar
Need to replace the emblem on the trunk as well. So there's no worries about peeling the paint when you remove the emblem? What else can you use if you don't have a heat gun?
Old May 27, 2007 | 01:11 AM
camry313's Avatar
Hi ...
if u don't have a heat gun ... u can use insted a HAIR DRYER ... it's not a joke ,,, i use to remove the stickers that vi had on my previous car by using the hair dryer as a heat gun & it really works
Old May 28, 2007 | 02:02 PM
gslrider's Avatar
Thanks! I'll give that a go.
