2011 Camry le not JBL Radio Wiring
Old Feb 18, 2012 | 05:11 PM
dmarr35's Avatar
Default 2011 Camry le not JBL Radio Wiring
I need color code wiring for standard radio not JBL Thank YOU
Old Feb 19, 2012 | 02:48 PM
Might be:
Gray = ACC
Blue/Yel = Power
Brown = Ground
Violet & Pink = Frt Door LH
Blue & Light Green = FD LR
Yel & Blk = Rear LH
White & Red = Rr RH
Old Feb 19, 2012 | 03:39 PM
dmarr35's Avatar
Thank You Joey P I have a RaadWire radio I am installing I figured it out except the ant on factory has 2 inputs and when I put the large one in I get poor reception I will have to contact RoadWire for ome help the stering wheel also does not work.
Old Feb 19, 2012 | 11:37 PM
The large cable may be the antenna.
What color is the other antenna wire, orange? If so this is for a antenna amp.
Old Feb 20, 2012 | 05:38 AM
dmarr35's Avatar
It is blue smaller then black
Old Feb 20, 2012 | 10:00 PM
Is the antenna built into the rear window, on top of the car, a mast antenna and if so automatic extend and retract?
Old Feb 21, 2012 | 05:35 AM
dmarr35's Avatar
Problem fixed power to ant was not hooked up I did not has a wiring diagram so I retraced the few wirers I did not use it says orange for ant but it was brown, Radio is great now Thank You.
Old Feb 23, 2012 | 02:29 PM
mikejordan's Avatar
while comparing black it is big and blue in color
Old Jan 25, 2013 | 05:57 AM
igorep's Avatar
what is the blue smaller then black wire with small brown wire connected to, the reason why I'm asking is because I installed aftermarket double din sys and it did not had any input for this cable and now I have some issues with the radio signal.
lonewolf41
Mar 2, 2020 05:48 AM
highalti2d
Jun 20, 2015 10:26 AM
jkrueger2020
May 12, 2015 11:46 AM
SSanchez10
Jul 30, 2011 06:46 PM
azngotskills
Feb 1, 2011 06:44 PM
