Capacitors
Old Oct 30, 2007 | 11:13 PM
  #11
JRMusic707's Avatar
Default RE: Capacitors
Alright. Thanks.
Old Nov 28, 2007 | 11:30 AM
  #12
Spazc's Avatar
you might wanna try upgrading the "big 3" before you go an buy a cap. in many cases this can reduce or even eliminate your need for a cap.
this tutorial was posted by DYohn on the12volt.com forums.
Since this question comes up again and again here, I thought this might be a useful post. Performing a "Big 3" upgrade on your vehicle is one way to improve the electrical system performance and its ability to supply power to your audio system. This upgrade will help any vehicle using an after-market amplified stereo system, and most certainly should be performed on any vehicle after a high-output alternator is installed. Please be sure you read and understand this entire instruction before you begin. Definition: the "Big Three" upgrade means improving the current capacity of three cables: 1) alternator positive to battery positive, 2) battery negative to chassis, and 3) engine ground to chassis. Some people replace the factory wiring; others add additional cables to the factory wiring. This instruction is to add cables to existing OEM wiring. Parts and Tools: As a minimum, you will need to purchase the following: •Sufficient length of high-strand count high capacity power cable.
- The length required differs for every vehicle. You can measure the length of the existing cables and buy the same length, or contact your dealer or a mechanic and ask, or sometimes you can look it up in a manufacturer's wiring book, or guess. If you guess, make sure you over-estimate and buy too much.
- High strand count cable is more flexible and more reliable than low-strand count cable. Never use solid-core wire in a moving vehicle as it will eventually break.
- The gauge of wire you need depends on the total current draw of your audio system, and/or the current generating capacity of your alternator. Never use smaller cable that you used to power your amps; never use smaller cable than what already exists in your vehicle; never use smaller cable than the generating capacity of your alternator; never use smaller than 4 AWG (it's just not worth the time to use anything smaller); if in doubt, always use higher gauge cable than you think you need. If you look at the Power and Ground charts and your amplifier current draw corresponds to 2 AWG cable, use no smaller than 2 AWG cable, and use 1/0 if you can. •6 ring terminals or lugs of the appropriate size for the cable chosen. Two of these need to be large enough to fit over your battery posts, or appropriately sized to bolt onto your existing battery terminals.
•1/2" or 5/8" shrink tubing (or some other form of permanent electrical insulation. Tape is NOT recommended.)
•Cable ties (plastic zip ties.) •Wire cutters large enough to handle the cable you choose.
•Crimpers large enough to handle the connectors you choose.
•Soldering iron or gun.
•Solder.
•Scotch brite and/or a small wire brush.
•Heat gun.
•Safety razor blade (or other tool for stripping cable).
•Heat gun (if using shrink tubing).
•Wrenches for removing bolts in your vehicle. Procedure: 1. Make sure your engine is completely cool before beginning. Identify the three cables being replaced. Make sure you can reach both ends of all cables. NOTE: the engine block to chassis cable may be between the engine and the transmission, or connected to the transmission and the fire wall, and is often an un-insulated flat braid cable. 2. Determine the lengths of cable needed to reach between the three locations being upgraded. Be sure you measure with a flexible tape (a tape measure used for sewing works great) and record the total length along the path you intend to install the cable. You do not want your cables to be pulled tight between any two locations as things move and vibrate as you drive. Be sure to include at least 1 inch extra for slack. NOTE: there is no reason to copy the existing wiring layout in your vehicle unless you want to. Also, be sure that the path you choose does not follow or lay across anything that gets hot, like exhaust parts, or anything that must move, like throttle linkage. 3. Cut your new cable to the three proper lengths. NOTE: some people like to use red cable for positive and black cable for negative. Doing this is completely up to you and is nice, but not necessary. You can use cable with any color insulation you like. 4. Strip each end of all cables to the proper length for the terminal lugs being used. NOTE: after full insertion into the lug, a small "band" of bare wire is usually seen between the back of the lug and the beginning of the cable insulation. 5. Begin at any one end and insert the stripped cable into the lug. Make sure it is fully inserted. Crimp the connector to hold the wire in place. NOTE: crimping large cable can be difficult. The intention here is not to make the crimp the sole means of holding the wire, but only to make sure the lug does not slip around during the soldering phase. I do NOT recommend using hammers or pliers or vices to crimp the connector as over-crimping can break the strands of the cable, reducing the current carrying capacity. Do not over-crimp. 6. You may need to use a vise or some other set of "helping hands" to hold the cable while you solder it. Heat your soldering iron and place iton the connector (on the lug side) barrel. Hold a piece of solder against the tip of the iron and melt the solder into the strands of the cable. Use sufficient solder to fill the connector and completely cover all strands of the cable. NOTE: the lug will get hot and will burn you if you try to hold it. Also, if the insulation on the cable starts to melt, you are over-heating the cable and not paying attention to melting the solder into the cable. You do not need to try and melt the cable! 7. Repeat the above steps on each end of all three cables. 8. After the cables have completely cooled, cut a piece of shrink tubing long enough to cover the soldered barrel end of the lugs and reach about 1/2" onto the insulation of each cable end. Slide this over each lug and use a heat gun to recover the tubing in place. 9. Disconnect your battery, starting with the negative cable first then the positive cable. Discharge any caps you may have in the system. 10. Begin adding your new cables along side the existing ones. I usually begin with the alternator positive cable. Locate the output stud on your alternator and remove the nut. Slip the new cable onto the lug and replace the nut. There is no need to disturb the existing cabling. Route the new cable to the battery and position it to connect to the positive battery post (or connect it to the positive terminal on the OEM wiring) but do not connect the battery yet. 11. Secure the new cable in place by using cable ties every 6 to 8 inches. Secure the cable to cool non-moving parts! 12. Locate where the negative battery cable attaches to the vehicle chassis. Remove this bolt and the OEM battery cable, and clean the mounting area of the chassis using scotch brite and/or a wire brush. Make sure there is no dirt, rust, paint, undercoating, etc in this location. You want bright shiny metal. Connect both your new ground and the OEM ground back to the chassis. NOTE: Some people like to create a new ground location by drilling into the chassis and using a bolt with star lock washers for the new ground cable. Route this new cable back to the battery and position it to be attached, or connect it to the negative terminal. Do not reconnect the battery yet. 13. Secure the negative cable using cable ties every 6-8 inches. Again, don't tie it to anything that moves or that gets hot! 14. Disconnect the engine ground strap at both ends. Using the wire brush or scotch brite, clean both the engine block and the chassis as you did for the first ground strap. 15. Line up the lugs on both the OEM ground strap and your new ground cable, and use cable ties to secure them to each other. This is much easier to accomplish in your lap or on the floor than it is while lying under your car or hanging upside down in the engine compartment. Reinstall both cables at the same time using the factory bolts. 16. Double check to make sure all bolts are tight. Be careful not to over-tighten them as you don't want to strip anything! Also, on some factory alternators it is WAY too easy to twist off the positive output lug. If you break it off, well hell, you really wanted a high-output alternator anyway, right? It is also a good idea at this point to measure resistance of the new cables. Take an ohm reading between the battery end of the new ground cable and the engine block. It should read less than one ohm. Also check between the alternator bolt and the disconnected positive battery terminal, which should also be less than one ohm. If you read too high resistance, double check all connections and make sure you do not have something c**ked sideways or hanging loose. NOTE: Realize that the "absolute ground" ofthe electrical system is not the battery negative terminal or the vehicle chassis, but is the case of the alternator itself. This is why perhaps the most important cable among the Big 3 is the engine ground strap, as this is what connects the alternator ground to the vehicle's chassis. Be certain the resistance between the alternator case (the engine block assuming the alternator is properly bolted to the engine) and the battery negative is minimized. (Thanks to the12volt for pointing this out!) 17. When you are sure you are done and anything in your system that you may have disconnected are re-connected, clean your battery posts and reconnect the positive battery terminal first, then the negative one. 18. Start your vehicle. Hopefully the engine starts. Examine the engine compartment and make sure none of your cables are getting hot or are vibrating or shaking around. If they are vibrating too much you may need to relocate them or use more cable ties. If you see smoke, immediately shut off the car and disconnect the battery. Seek help. 19. Assuming all looks good, take a voltage reading at your amplifier and ensure you read 13.8 (or higher) volts. This indicates a properly operating charging system. 20. Now'd be a good time to turn it on and make sure it sounds good! Then of course log onto the12volt.com and post that you have upgraded your Big 3!
Old Dec 6, 2007 | 11:28 PM
  #13
Dave_Edwards's Avatar
What are you talking about????[/align][/align] A TermLab does NOT measure the quality....it measures pressure (dBDrag/Meca use this unit)[/align] The AudioControl unit measures actual sound(not many people go by these numbers anymore....maybe smaller local shows)[/align][/align]and as for caps making the sound quality better??? Where do you get your info?[/align][/align]Caps are useless......if your lights are dimming already why would you add to the load of the battery and alternator by adding a capacitor? It makes no sense, use the money elsewhere...IE larger power wire(that's right it is ok to run bigger than 4 guage), maybe even getting a high-output alternator or larger battery....I can think of a hundred other uses for the money.....BTW I will be using 5500 watts of PG/Sundown power in my camry and guess what.....no caps here.....hope this helps[/align][/align]I am a Senior member and an admin on SoundSolutionsAudio.com[/align][/align][/align][/align][/align]
ORIGINAL: Black95Cam
haha.. nice.
forgot to tell you, ask if they use a termlab or audio control. (term lab measure the quality while the audio control measue the air pressure)
[/align]
Old Dec 8, 2007 | 10:42 PM
  #14
Black95Cam's Avatar
good for you mister know it all.. every system is different in each car... yeah i know im goofed up the termlab but as far as my system went, it did help the sound quality after i added a cap... i seen 20,000 watt system that dont use cap. they use batterys.. yeah no duh you can run bigger wires then 4 ga.. some of us dont have that kind of money thus smaller weaker system.. but hey im just a college student what do i know...
