02 camry rear brake pads
Typically old pads are thinner then the new ones due to wear.
As a pad wears the piston forcing the pad against the rotor moves forward.
When you attempt to replace the old worn pad with a new, thicker one, the piston (now extended) prevents the pad from being installed.
The piston needs to be pushed back to make room for the new, thicker pad.
If you have ABS, the best route is to loosen the bleeder on the caliper to relieve fluid pressure when pushing back the piston. This will prevent the fluid from backing up into the ABS control system and possible causing operational issues.
I did compress caliper in still cant get caliper over new pads. Does caliper move out of postion when this is done. Plenty of room for inside pad not engough clearance for outside pad. should i remove top bolt of caliper?
You may think you moved the piston all the way in but if its just a little out you won't get the caliper back on. It has to go over if you have it in all the way.
If you are talking about the bleeder bolt on top, I would not undo that. You should be able to press in the piston enough without opening that up. Also, if you do open it up, be sure to know how to bleed brakes as that will induce air into the lines.
J2Performance
Dec 18, 2007 12:18 PM
J2Performance
Dec 17, 2007 03:51 PM
J2Performance
Dec 12, 2007 05:12 PM
J2Performance
Dec 12, 2007 04:55 PM
Yoo Shin
Mar 12, 2007 05:20 AM
, does it work?
