1991 camry cruise control issue
I recently changed the Nipondenso alternator on a 1991 Camry. Now the cruise control wont work (actually it seems to work backwards).
Would pass on the love if someone could help......
Try the following:
Turn ign on
Turn set/coast switch on and keep on
Push main switch on
Turn set/coast switch off
Turn set/coast switch on-Watch cruise control light. Light should blink 2 times, pause, 2 times then repeat if switch system is normal.
Perform the next test below:
When driving at 10 mph or less press set/coast switch 3 times in 2 seconds then watch cruise indicator light. If all systems are normal light will flash at a constant rate. If not light will flash, then pause, then flash again, then repeat the sequence of flashes and pauses. Record number of number flashes/pause/number of flashes.
Turn ign on
Push main switch on
