1996 2.2 4cyl Transmission
Old Feb 19, 2019 | 05:41 PM
vd2kilcm's Avatar
Default 1996 2.2 4cyl Transmission
New here...thanks for taking time to look over this post. I'm working on a 96 2.2 and a switch located behind the shift indicator switch broke off, and I'm trying to identify it. Its located, as you're looking from the front down into the engine bay, immediately to the left of the kickdown cable, and appears to bolt into the transmission housing. Forgive my ignorance, but what is this switch called and what is its function?
Old Feb 20, 2019 | 11:14 AM
Old Feb 20, 2019 | 08:29 PM
vd2kilcm's Avatar
No, unfortunately. This.
https://www.rockauto.com/en/catalog/toyota,1996,camry,2.2l+l4,1273520,transmission-automatic,shift+solenoid,8476
Old Feb 21, 2019 | 09:45 AM
Which part number on the list of parts for the link you provided?
This part is located on the outside or the inside the trans housing?
Can you take a photo?
The parts on the list are easily replaceable. You do need to know what specific part to get.
Old Feb 21, 2019 | 07:35 PM
vd2kilcm's Avatar
I found it. Thank you for your help.
BIC
Oct 28, 2015 03:43 PM
Johnjacobsen
Mar 14, 2015 08:45 PM
James Berger
Jan 30, 2013 01:08 PM
katieblazer91
Aug 7, 2008 05:23 PM
bobway
Aug 18, 2005 06:00 PM
