1997 Totyota Camry Tail Lamp Passenger side
Old Sep 17, 2010 | 03:37 PM
mandarp02's Avatar
Default 1997 Totyota Camry Tail Lamp Passenger side
How to replace the tail lamp passenger side of the Toyota Camry 1997 2.2lt model?
Old Sep 17, 2010 | 09:06 PM
The lamps are typically accessed from inside the trunk. Find the area inside the trunk behind the burned out bulb location. If there is not a door, pull back the trunk liner. You may need to remove a few plastic push plugs that hold the liner in place. You should see the back of the lamp fixture having a plastic bulb holder. The holder twists to remove.
Old Sep 18, 2010 | 11:22 AM
mandarp02's Avatar
Is there any video available for the same as my whole lamp assembly needs to be replaced. and where can I find the cheap and best deal for the tail lamp passenger side of Toyota Camry 1997 Japan build model?
Old Sep 21, 2010 | 05:48 PM
johne's Avatar
Try rockauto.com They are around $45/each.
baejinsu
Sep 13, 2011 08:55 AM
wkoncelik
Aug 20, 2010 11:48 AM
mheredia2930
Jun 3, 2009 11:43 AM
TKOTed
Oct 15, 2008 03:23 AM
jenm01
Feb 14, 2008 11:37 PM
