2003 Toyota Camry
Old Aug 4, 2023 | 09:29 AM
Jimcan's Avatar
Default 2003 Toyota Camry
I have a 2003 Toyota Camry with the 2.4 L 2AZFE engine it is the Japan version. I found a 2006 Toyota Camry with the same engine just it was manufactured in the United States. I was wondering if I have to switch anything out on it or emissions or anything I’m assuming one has federal and the other one has California
Old Aug 4, 2023 | 01:58 PM
There is a sticker on the side of the drivers door stating if the car is California or Federal compliant.
Between years Toyota changed the throttle body, throttle position sensor and knock sensor designs.
Old Aug 4, 2023 | 04:54 PM
Jimcan's Avatar
Ok that’s what was thinking so I will just use the ones that came off the original engine think you
Old Aug 4, 2023 | 07:57 PM
Sounds good.
Old Jan 11, 2025 | 08:42 AM
aaronc's Avatar
did you ever figure anything out? I did a swap similar to this and the car will start but die almost immediately.
Old Mar 30, 2025 | 01:50 PM
aaronc's Avatar
Or mine workin fine with just a few components being switched over, kept dying because my intake boot was loose
Old Mar 30, 2025 | 04:55 PM
Nice job!
Kacgraphics
Aug 15, 2015 12:08 AM
oldtown
Oct 16, 2013 05:56 AM
Irison
May 11, 2013 12:38 PM
idealg
Mar 14, 2012 08:40 PM
zcpro
Jul 11, 2009 11:58 AM
