2003
Old Oct 15, 2013 | 06:08 AM
oldtown's Avatar
Default 2003
camry burns oil after being overheated. has 177,000 miles any suggestions? thank you
Old Oct 15, 2013 | 12:44 PM
Engine model?
How much oil is burned per 1000 miles.
Old Oct 15, 2013 | 05:42 PM
oldtown's Avatar
Default oil
two an a half per 5 thousand miles
Old Oct 15, 2013 | 07:04 PM
oldtown's Avatar
4 cylinder
Old Oct 15, 2013 | 07:38 PM
It is possible the now hotter oil plugged up the oil drain holes on the piston. This engine has a problem with this and oil consumption starting 70-90K, the over heating may have hurried things along. Or the cylinders were scored, or both.
On the off chance, check the PCV system for plugging which can increase pressure inside the engine.
Watch the coolant level as this engine also has a problem with 3 or 4 head bolt threads pulling out of block causing leakage.
Most likely not much can be done without taking the engine apart.
Old Oct 16, 2013 | 05:56 AM
oldtown's Avatar
It's too bad this happened to this car. Serpentine belt broke an my wife drove it till it ran out of water. Engine still looks like new, so does the car. Thank you for your imput. Time to trade
idahoruss
Nov 25, 2006 10:39 PM
JoeGengsta
Jun 28, 2006 11:31 AM
daileisu
May 31, 2006 08:10 PM
yianni
May 30, 2006 02:22 AM
arafat_camry
Aug 8, 2005 09:57 PM
