2022 Camry SE FWD - Hood Struts
Hello!
I just wanted to let anyone know who may be considering adding hood struts to their 2022 Camry, that the parts from a 2018-2021 will fit.
I just finished installing this today - and it is much nicer than that support rod.
Hood Lift Support Struts OEM:
53440-06180 - $60 Left Cylinder Strut
53450-06150 - $60 Right Cylinder Strut
Or you can do what I did - Aftermarket Struts: $38 for the pair
Rest of the parts needed:
53337-06070 - $5 Left Front Upper Cylinder Bracket
53482-06140 - $7 Left Front Lower Cylinder Bracket
53481-06160 - $7 Right Front Lower Cylinder Bracket
53336-06080 - $5 Right Front Upper Cylinder Bracket
90119-A0479 - $1 each (Need 4) Bolts
With the aftermarket struts I'm only out $65 to make it happen. You have to remove trim pieces on each side of the Engine compartment but they snap off and on fairly easy.
Hope this helps!
I followed this guys video:
Hope this helps!
Complete hood strut lift kit compatible with Camry 2018 2019 2020 2021 2022 2023 2024 Toyota Camry. Hood Strut Lift Complete Kit With Factory OEM Mounting Hardware https://a.co/d/3KuQWbL
stevel
Mar 3, 2015 11:01 AM
d72hemi
Jun 3, 2012 01:39 PM
