3-rib serpentine belt on my 2002 2.4L Camry
Old Nov 26, 2017 | 03:28 PM
Al.C's Avatar
Default 3-rib serpentine belt on my 2002 2.4L Camry
I checked under the hood to investigate belt noise and found my serpentine belt was only 3 ribs and half the pulley width. I wonder how that happened? The ribs were cracking so I've ordered a replacement Dayco 5070763. Youtube videos make this repair look pretty straightforward. I also noticed some light rust on the exposed pulley ribs. Any thoughts?
Old Nov 26, 2017 | 07:39 PM
Check pulley grooves for debris, pebbles, nicks, etc. that could cause damage the belt over time.
Run/rev engine and check if something is hitting the belt.
Check pulleys for excess play/wobble.
Old Dec 8, 2017 | 06:22 PM
Al.C's Avatar
I finally got around to doing the belt replacement yesterday, delayed by a HoLEP prostate removal on 11/29 along with a bladder stone and a kidney stone all in one go! Traveled 2000 miles to Indianapolis where IU Health at Methodist Hospital have the expertise and accept Medicare. Good luck to you young guys for what they are planning to do to Medicare, you're gonna need it. I digress... The old 3 rib belt came off easily, I used the 19mm box end wrench with a second wrench added for leverage. Took another 20 minutes to get the new belt in position after checking the idler pulley bearings were good. Three strategically placed flashlights helped and I chose to use the smooth idler pulley instead of the ridged alternator pulley as the final pulley to complete the assembly. Thank goodness for contributors to forums like these and YouTube videos!
Old Dec 8, 2017 | 09:07 PM
Great job!
tvsdprasad
May 22, 2015 02:34 AM
elopomorph
Aug 15, 2013 09:00 PM
califmonster
Aug 11, 2012 11:30 AM
theguysaid038
Dec 16, 2008 07:05 PM
berries674
Mar 23, 2008 01:45 PM
