93 Camry radiator fan always on
Old Aug 29, 2011 | 09:32 PM
newbie888's Avatar
Default 93 Camry radiator fan always on
Is is normal for the radiator fan to run all the time? If I disconnect the fan switch (mine is connected on the thermostat cover), the fan runs full throttle. However, when the switch is connected and I start the car, the fan turn on and run in about half the speed and stay on all the time. It doesn't matter if the A/C is on/off. If it should be on all the time, what could be the problem?
Thank You.
Old Aug 30, 2011 | 11:56 AM
newbie888's Avatar
Ok, I found out this is how the fan is designed to operate for a '93 V6(3VZ-FE) Camry.
spaghetti
Jan 10, 2014 05:36 PM
EarlT
Mar 31, 2010 10:50 AM
pewterpower
May 2, 2009 10:22 PM
python
Apr 5, 2008 08:10 AM
98camryblue
Nov 25, 2007 06:40 PM
