94 Camry Fuel Pump
Old Mar 30, 2012 | 09:08 PM
WJM's Avatar
WJM
Default 94 Camry Fuel Pump
Hello new to the Forum
I think my fuel pump is out. I checked it the old fashion way and attached an old fuel line to see if the pump was pumping while cranking the engine over. No fuel came out while cranking the engine over.
Diagnoses: need new fuel pump.
Correct?
Old Mar 30, 2012 | 11:15 PM
Look in the engine compartment on the drivers or passengers side strut tower for a small plastic box about 1 x 2 inches. Inside are electrical terminals. Use a section of wire or bent paper clip to connect the FP and B+ terminals. Once done the pump will power up when the ign key is turned on.
Test the pump again. If no noise check for DC power to the fuel pump at blue/black wire. Make sure the white/black wire is grounded.
If noise but no fuel make sure the filter sock at the bottom of the pump is not plugged.
If all OK then look at the pump.
Also take note there are two fuel lines. One comes from the pump, the other is return fuel. You want the line having the steel nut attach fitting to the pump tube not hose clamps.
joea
Jun 30, 2014 10:25 PM
Bam Bam 65
Oct 20, 2013 05:54 PM
KEVAUG
Mar 17, 2012 12:19 AM
camaropoor
Jul 23, 2010 10:16 AM
