Air Conditioning Not Working
Old Sep 15, 2020 | 06:50 PM
  #11
Try asking at Toyotanation.com Camry section.
Old Sep 15, 2020 | 08:50 PM
  #12
grumpy56's Avatar
Will do. Thank you.
Old Oct 7, 2020 | 05:01 PM
  #13
grumpy56's Avatar
Well to sum up....A/C now working. Converted it to R134a, replaced relays, compressor (was leaking), and dryer and it worked, except at idle. Turns out I also had a bad idle-up VSV and after putting on a new one, A/C problem FINALLY solved. Appreciate your help
Old Oct 7, 2020 | 11:06 PM
  #14
Great job. Persistence pays off.
Old Oct 8, 2020 | 08:40 AM
  #15
grumpy56's Avatar
Thank you Joey P!
Old Jul 22, 2021 | 08:26 PM
  #16
pristick's Avatar
Banned
Air conditioning is essential not only to clean the air but also to prevent general room pollution. If the air in the room is not ventilated, then the room will get dirty more often, and in this case, you will have to clean it more often. Alternatively, you can use the services of a cleaning company from https://www.emop.co.uk/southwark-cleaner. They have a large staff of specialists, and their work can be easily controlled through the application.
Old Jul 22, 2021 | 10:05 PM
  #17
grumpy56's Avatar
I don't use the car much and it had been a few years of not working at idle. But good to go now!!
grumpy56
Sep 26, 2019 09:09 AM
shakebaker
Aug 8, 2012 08:43 PM
foxyroxy111298
Jun 6, 2011 11:02 AM
hashubek
Sep 1, 2008 11:46 AM
dinh
Feb 25, 2008 12:19 PM
