Antifreeze
The block may not have a drain plug. If you want it all out need to drain radiator and refill with distilled water. Then operate car to mix things and drain again. Do this a few times. Keep track of the quantity of liquid that come out as you want to put the same amount back in to know the system is filled.
What color is the coolant you have? Toyota brand is pink or red.
I use Valvoline Zerex Asian RED Vehicle Antifreeze / Coolant - 1 Gallon Already Mixed Walmart
