Brake/Tail Light bulb has rusted to fixture...now what?
I own a 1995 Camry, and there has been a slow water leak into my left tail light over the years. I've had to replace this bulb a few times before, but this time the metal from the bulb has rusted and bonded with the fixture which makes it impossible to turn
. The bulb, being weak, came out of the metal which then only left the rusted metal (from the bulb) and the fixture.
Matters got worse onece I tried to use needle-nose pliers to turn and take it out. The metal bent, then broke off
, but the base of the metal was still stuck
Obviously, I'm thinking I'll need another fixture to replace this one because I don't see any way I'll be able to get that metal base out of the fixture
What should I or can I do in this situation?
. The bulb, being weak, came out of the metal which then only left the rusted metal (from the bulb) and the fixture. Matters got worse onece I tried to use needle-nose pliers to turn and take it out. The metal bent, then broke off
. Obviously, I'm thinking I'll need another fixture to replace this one because I don't see any way I'll be able to get that metal base out of the fixture
.What should I or can I do in this situation?
You should solder the new socket that Glenn8963 suggested you acquire from a junk yard. Use some shrink tube insulation on the wires where you connect them and while your at the junk yard get a new tail light so in doesn't happen again.
baejinsu
Sep 13, 2011 08:55 AM
job4mi
Oct 29, 2008 09:51 AM
Demiandvm
Aug 26, 2007 03:49 PM
