Old Aug 26, 2015, 04:05 PM
How-Tos on this Topic
Browse all: Interior
Print Wikipost
Changing the bulbs in a 2015 Camry XLE
Old Apr 1, 2015 | 09:55 AM
srjacob99's Avatar
Default Changing the bulbs in a 2015 Camry XLE
I have a 2015 Camry XLE with the sunroof. I want to change the interior bulbs to LEDs to give a better and brighter light. Unfortunately, the owner's manual doesn't discuss changing these bulbs.
I have spoken to the folks at XenonDepot, and they don't have a clue.
I have several questions:
-- Does anyone know how to get to these bulbs to remove them?
-- Does anyone know what the number of these bulbs are? In the owners manual (in the specification-light bulbs section) it mentions the front and rear interior/personal lights are wedge base bulbs, but not what number they are. The manual also talks about an Interior light as a double end bulb, but I have no clue what this is (perhaps for the non-sunroof car).
-- Does anyone know of a good place to get the LED replacement lamps?
Thanks for all your help.
Steve
Old Apr 1, 2015 | 10:33 AM
Check the manual for a list of bulbs used in the car listed by part number or wattage?
The interior reading/map lights may use a wedge base bulb, model 2825.
LED bulbs are available as 2825 and 168/194/2825 (one size fits all). See link below:
https://www.google.com/search?q=2825...sm=93&ie=UTF-8
The bulbs pulls out from its base.
The dome light may be a double ended bulb also called a festoon cap bulb, see link below:
http://www.bulbtown.com/category_s/436.htm
This bulb is held in a each end by a metal tab.
At one time OEM bulbs were slightly smaller and having a slightly different design. A standard size bulb would fit but it needed to be forced into place. Available LED bulbs may also be slightly larger then OEM. See link below:
https://www.google.com/search?q=LED+...sm=93&ie=UTF-8
LED bulbs for both base styles are available at auto parts stores and places like Wal-Mart.
The internet has video's on removing the dome light. The cover needs to be gently pried off.
Paul79UF
Nov 13, 2021 08:24 AM
cheapheart
Apr 24, 2015 10:33 AM
Richard Kaplan
Nov 29, 2014 05:36 PM
mitchybizzle
Sep 27, 2008 02:03 PM
ecoflex
Aug 18, 2007 09:11 PM
