Code P0355
Old Nov 5, 2015 | 03:05 PM
seasam's Avatar
Default Code P0355
Hi everyone,
Thanks for helping out! My girlfriend's car recently turned on the "check engine" light and she diagnosed it with her Automatic plugin device. The code that came up was "P0355 - Ignition Coil E Primary Control Circuit/Open". She took it into the shop yesterday and they "fixed it" but it came back on today with the same warning code.
Any advice on how to troubleshoot and what to tell or ask of the technicians?
Thanks again for the help!
EDIT: also, can she drive on it for the time being?
Old Nov 5, 2015 | 04:36 PM
dirty hands's Avatar
yes I have had to fix a camry with this problem
wish i knew what year the car was ...Is this a 4 cylinder ?
I will give you this answer for now
if so
the motor should be running rough at times when hot ... or lack a bit of power under load
try this
you may have a faulty coil pack ..... its the bit sitting above the spark plug
find the one that is faulty and replace it .. you .dont have to replace all 4
what this fault code means
DTC P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
Old Mar 10, 2016 | 11:06 AM
Flip5ide's Avatar
how do you diagnose which coil is not working properly?
if so
try this
Old Mar 10, 2016 | 11:25 AM
What year of car and engine type?
Old Mar 10, 2016 | 11:31 AM
Flip5ide's Avatar
2007 camry v6, the scan gave a ignition coil code. how to I diagnose exactly which coil/s is not working
Old Mar 10, 2016 | 10:47 PM
P0355 is the ign coil for the No 5 cylinder.
No 5 is on the cylinder bank closest to the firewall and on the far drivers side of engine.
KEVAUG
Jun 17, 2012 08:01 PM
bayarea2VZ-FE
Apr 27, 2010 07:13 PM
mgoofy24
Sep 24, 2007 04:56 PM
camryluvr
Apr 5, 2005 03:31 PM
camryluvr
Apr 5, 2005 11:24 AM
