DLC2 and OBD SCAN Tool
Old Mar 24, 2010 | 02:58 PM
nj08820's Avatar
Default DLC2 and OBD SCAN Tool
I have the check engine light on my 1994 Camry LE V6, and I went to Autozone. They don't have a tool that will read the OBD code from the round connector located on the bottom left of the dashboard pointing downwards with a lid on top. How/where can I get the OBD code read, besides the obvious places like Toyota dealership?
Thanks
Old Mar 25, 2010 | 10:04 AM
This may be a transitional year.
Some owners have stated there is a second plug behind the drivers side ash/coin try.
You may need an adapter plug.
Is there a Pep Boys in the area.
Old Mar 26, 2010 | 05:38 AM
nj08820's Avatar
There are pepboys in the area but I don't think they do anything for free or cheap. Do they?
Old Mar 26, 2010 | 12:08 PM
nj08820's Avatar
Smile
Thanks for reminding about the location of the OBD connector. I knew it was there but could not easily see it.
Found the connector and used an OBD II scanner at Advanced Auto Parts. It indicates P0773 Shift Solenoid E Electrical...
Wonder if this is easily fixable or a pricy one.
Old Mar 26, 2010 | 08:34 PM
This is the torque converter lockup solenoid. The solenoid can be accessed from outside the transmission case.
Suggest doing a Google search on this code and the word Camry. Reading the hits should give you an idea of the problem, how to check the solenoid and replacing it.
If your handy with tools you can do the job yourself.
The solenoid should be available on the aftermarket. Toyota calls it the "SL" or "E" solenoid.
crazylove
Aug 16, 2013 02:59 AM
patrick-xie
Jun 23, 2013 10:21 PM
the_iklop
Jan 5, 2013 09:44 PM
crazylove
Jun 15, 2012 09:05 PM
Panther37
Nov 14, 2005 03:58 AM
