Engine swap
Old Jan 18, 2012 | 08:28 PM
baran46's Avatar
Default Engine swap
greetings everyone. thinking to swap engines on my 97 camry. its v4 2.2. thinking to put engine from same model car v6. is it bold in action? and will i need to swat transmission as well if i put v6 in?
Old Jan 19, 2012 | 09:56 AM
The V6 was an option as such the engine and trans will bolt in.
You will need another model of trans, assume an A541E. The 4 cylinder has an A140E trans.
And a computer for the new engine/trans model a(both will be different) plus the emission type for the car. The either meets Federal or California standards. The emissions type will also effect the V6 engine chosen as Fed or CA engines have slightly different builds.
The engine harness will need to be swapped.
The V6 option has heavier front suspension spring for the added weight plus 4 wheel disk brakes.
The swap have been done but highly suggest you have a Camry of similar year with V6 available for a donor car.
If piecing the swap together instead of getting all the parts at once the costs are going to add.
Might be cheaper to sell the old car and buy one with a V6.
Old Jan 19, 2012 | 05:19 PM
baran46's Avatar
thank you for reply. very informative. I've done swaps on BMW's and its completely different.
Basically no point in doing it. =]]
upjeeper
Oct 25, 2012 01:56 PM
carlos1787
May 23, 2009 05:57 AM
scotbot
Sep 12, 2006 09:31 PM
Serenityvalley
May 15, 2006 06:03 PM
