Front end taller after strut/spring replacement??
Old Jul 27, 2024 | 05:04 PM
KINGJOHN's Avatar
Default Front end taller after strut/spring replacement??
Aloha!
2007, Camry XLE, V6, Automatic trans. 18x8 wheels, 245/45/18 tires.
Just recently installed new springs/strut assembly on my Camry. Problem is, it raised the car by at least 2" or so. Contacted the manufacture and was told that the spring/strut assembly purchased only puts the car back to OEM height. Because I didn't measure the fender to hub, don't know what OEM height is, just know that the new suspension raised it noticeably higher than it was.
Anyone know what the actual "OEM" height is from fender to hub?
Thanks in advance.
Old Jul 28, 2024 | 01:11 AM
That is hard to know for sure as it can't be easily searched on the interwebs.
Maybe somebody with the same gen camry can chime in.
2" is pretty significant, will it settle a little bit after time?
cphcajun
Jul 20, 2023 03:25 PM
CamIRide
10
Apr 6, 2022 04:08 PM
ozieagle
Jan 18, 2013 07:58 PM
pyramid14
Jul 28, 2008 11:54 AM
purplecamry
Mar 13, 2008 02:21 PM
