Rear ABS Sensor
Need help with replacing the left rear abs sensor. I see where it is on the bottom of the strut, where does it go after it enters into the fenderwell. I was replacing the strut and let the wire get stretched out and now I have the ABS light on, on the dash. Any help would be appreciated. The car is a 98 Camry.
Kevin
Kevin
Isn't there a connector at the sensor. Is more likely that the small pins in the connector are not making a good contact. Unplug the connector and check the resistance across the sensor Then make sure the female pins are not spread.
