99le ABS sensor replacement
Old Jun 19, 2012 | 07:07 PM
DROB's Avatar
Default 99le ABS sensor replacement
Hello everyone. Does anyone know if the left rear ABS sensor from a 98 is comparable with my 99? The wires came out and a local junkyard has one from a 98for cheap. Also, any advise on that repair?
Old Dec 11, 2012 | 09:43 PM
Timmy99LE's Avatar
I know you posted this a while ago but the part and the car are compatible. I need to change my right rear as well on my 99 but I haven't yet so I can't give you the full ins and outs of the job, usually it's bolt off, unplug then bolt on and plug and go
Old Dec 12, 2012 | 08:26 AM
DROB's Avatar
Thanks for the tip. I actually did the job. I ended up getting a new sensor on ebay motors for $15 and it worked like a charm. The installation wasn't complicated necessarily, but I did have to take the old one out in pieces and lubricate the o-rings to get the new one in. The corrosion was pretty bad in that area.
Old Dec 13, 2012 | 07:38 PM
Timmy99LE's Avatar
I hate to be a pain in your *** but do you think you can PM me a step by step for that including any materials I'll need? I just went your route and bought one for my right rear and I just don't want to screw my car up.
Debunker
Dec 5, 2013 03:02 PM
DROB
Sep 5, 2012 10:13 AM
9612v
Apr 27, 2010 08:37 AM
granadaCoder
Jul 29, 2008 12:43 PM
dimon81
Sep 25, 2007 11:01 AM
