Repacking Wheel Bearings
Old Jul 12, 2018 | 09:50 PM
1989_Camry's Avatar
Default Repacking Wheel Bearings
For a 1989 Camry, how often should I repack front and rear wheel bearings?
Also, I recall on my 1986 Tercel that there's a certain number of tire spins that I can use to determine proper nut tightness, but is there a torque setting?
In other words, how do I know when I've tightened the nut?
Finally, is there a wheel packer bearing tool you'd recommend or is by hand fine?
Thanks!
Old Jul 12, 2018 | 11:01 PM
Wheel bearings are ball type, sealed and very difficult to access.
https://www.rockauto.com/en/moreinfo...272899&jsn=463
Old Jul 22, 2018 | 11:59 AM
wdc123's Avatar
I have a 1995 Camry V6 LE and have not done it yet but completed the task on many vehicles. In the old days you could repack but today the ones I have worked on are part of the steering knuckle ( must be removed), brought in to press out and install a new one, unless you have a press. They also last much longer.
This will take some time.
I am thinking about replacing since do not know how long they have been on there and will hear that noise.
speaker
Jul 31, 2019 06:59 AM
1989_Camry
Nov 10, 2015 06:24 AM
gibby
9
Feb 22, 2012 08:08 AM
lisam
Apr 16, 2009 12:24 PM
fulcrumpointftt
Aug 21, 2007 09:34 AM
