Vacuum lines and hoses replacement
Old Apr 25, 2026 | 06:51 PM
Sage's Avatar
Default Vacuum lines and hoses replacement
Hey there, I've got a 97' Camry 5S-FE with 268k miles. I replaced my motor mounts, and afterwards noticed a pretty big vacuum leak due to moving the engine so much in the engine bay. Several rubber hoses are cracked or in poor condition, so I've decided I want to overhaul as many rubber tubes as I can. Unfortunately, I don't have any tool I can use to measure the diameter of the hoses, nor can I find any documentation online. Many of the hoses are in bad shape and I don't know if I'll still be able to use them after removal for measuring. It's my work car and the other 'project' is currently not running. I've been unable to find any reliable documentation online covering all the tubes in the engine bay. Does anyone know of any resources I could use, or am I better off splurging for a tool to measure each tube once the other car is running?
This is my first post on the forum. If I should post this somewhere else let me know. Would appreciate any insight
Old Apr 27, 2026 | 10:32 PM
Are these small hoses such as going to the MAP sensor, ERG VSV, etc?
tonsOmiles
Feb 14, 2026 01:03 PM
Philbert
May 28, 2014 10:59 AM
d72hemi
Feb 19, 2013 08:18 PM
brianjrealtor
Feb 6, 2011 05:00 PM
geokor
Feb 6, 2007 02:49 PM
