Browse all: Wheels and Tires
- Toyota Camry 4th, 5th, and 6th gen How to Fix a Tire Leak
Vacuum Leak / Missing hose
Hey guys, I'm a little new to this, but here's my problem.
I've been suspecting, for several reasons, that I had a vacuum leak somewhere. So yesterday I finally got around to doing a smoke test. Well it didn't take long to find where the smoke was coming out, right behind the engine there is a little hose connection sticking out, but no hose in sight to connect to it. I looked through as many schematics and diagrams I could, and couldn't find anything. Does anyone know what this is, or what it connects to?
Thanks
Car info:
1995 Camry Wagon LE
5S-FE
188,782
Thanks
Car info:
1995 Camry Wagon LE
5S-FE
188,782
So I looked and there is nothing disconnected or loose on the throttle body, but thanks for the advice.
While I was looking some more, I came across the EGR VSV, and noticed there was something disconnected from it. When I was looking up VSVs in my haynes manual as well as online, I figured out that mine does not look like it's supposed too.
It makes me wonder if the two are related? Anyone an expert on EGR systems?
Here is a picture of my VSV and one of the normal configuration.
(mine is the one with the red lines)
The tube in the first post photos is between the 2nd and 3rd injectors?
The 95 Camry came in two versions, Federal and California state emissions. Each is slightly different which might explain your issue with not looking like the info you are finding.
Look under the hood for a sticker stating CALIF or FEDERAL, or something to this affect.
The California emissions car has a hose running from this spot to the IAC valve. The federal car has no such hose. Perhaps something was changed on the engine.
If no other vacant hose connection, suggest connecting a hose to the tube and capping it off.
So I don't see the vacant hose on the IAC valve.
But I started my car and went to check if the hose port was sucking air in, or blowing it out. And it's definitely for suction, when i put my finger close, it pulled it pretty hard. And when my finger tip cut off the suction, the engine just about died. So I can't just plug it.
Any other thoughts?
Any other thoughts?
Look under the hood for a diagram showing the vacuum hose layout, perhaps this hose is on the diagram.
Your engine may have been modified by someone, or federal-California emissions parts swapped.
Assuming your engine setup is correct. If the tube is drawing air, it should be drawing filtered air. Look for tube connections on the filtered air side of the air intake system. Such as on the filtered air side of the air filter box, along the intake air tube, etc.
