1995 camry cruise control
Old Feb 3, 2010 | 04:42 PM
eriknspice's Avatar
Default 1995 camry cruise control
Hi I have a 95 camry dx 5 speed and I know the cruise control module is bad. Do i need to replace it with one from a 5 speed camry also or can any cruise control module work?
Old Feb 3, 2010 | 07:10 PM
seems to be year specific.
A Google search will turn up 1995 Camry cruise models for sale.
Old Feb 4, 2010 | 11:31 AM
eriknspice's Avatar
oh okay thanks. it won't make a difference if mine is a manual transmission?
also, where is the module located? is it hard to get to?
Old Feb 4, 2010 | 11:42 AM
Looks like the passengers side upper kick panel area.
Appears not to make a difference if stick or auto. One wire attaches to the Neutral/Park or Clutch.
Have you tried accessing the self test feature of the unit?
There should be a round service electrical plug under the dash near the steering shaft area. Find the plug.
With ign switch on use a section of electrical wire to jump the Tc and E1 terminals. The cruise light will flash out a code number via flashes one numeral at a time. If no codes are stored the light will flash at a constant rate.
The E1 and Tc terminal are the inner 2 terminals in a bottom row of 6.
Old Feb 4, 2010 | 12:30 PM
eriknspice's Avatar
how do i tell what the codes mean? and thanks a lot you've been really helpful
Old Feb 4, 2010 | 12:42 PM
eriknspice's Avatar
okay i just bridged the two terminals and here's what i got:
1 flash, pause, 3 flashes
Old Feb 4, 2010 | 06:10 PM
Code 13
-Open circuit in actuator
-Position sensor signal value does not change when the cruise control motor operate
-Position sensor detects abnormal voltage
Send a Private Message with email address and will reply with troubleshooting info.
sa1997
Sep 15, 2009 07:23 AM
Cynical 1
Jun 17, 2009 03:04 PM
penhaifai
May 17, 2009 02:33 PM
viking
Sep 2, 2008 11:01 PM
viking
Sep 18, 2007 10:45 AM
