1998 Camry LE power lock issues.
Old May 6, 2020 | 07:46 AM
Thextallxdude's Avatar
Default 1998 Camry LE power lock issues.
Went to get out of my car today, and noticed the 'lock all doors' switch on both the drivers and passenger side no longer locks or unlocks the doors. When using the key to unlock all doors by turning the driver's side key to unlock twice, all doors unlock.
The 25A fuse for the doors and the 7.5A fuse for the done are still intact. My next step is to check the relay under the glove box, but as the key turn method works, I am unsure if this is the issue. Do the key unlock all and the switch use different relays, or does the key bypass the relay somehow?
Old May 6, 2020 | 09:20 PM
The key and door switches are wired to the integration relay which controls the door locks. There is some interconnecting wiring between the key and door switches. Might check the wiring for breaks.
willpine
Jul 12, 2021 10:49 AM
pcumming
Nov 27, 2013 06:49 PM
camryazn136
Apr 15, 2012 10:28 AM
samurai65
Aug 11, 2010 10:16 PM
aebomb
Oct 12, 2007 01:29 PM
