Air Control Knob light not working
Old Mar 10, 2011 | 07:11 AM
f0rsakens0uljah's Avatar
Default Air Control **** light not working
Hey guys, hope you can help me out with a small problem that I am having.
I owe a 2006 Toyota Camry and recently the light on the air control **** (**** where you can select where the air is blowing ) went out. All the other light on the panel is still working fine so the temperature and speed/strength still works fine. When I press the button on the air flow control **** it lights up for the rear defogger. Any idea what the problem might be? Is it a blown fuse? and if it is can you tell me which fuse it would be. Or is it the bulb itself? and if it is a tip on removing the panel to replace the bulb. Thanks alot guys.
Old Mar 10, 2011 | 10:24 AM
As just one light, most likely the bulb.
Not sure how to replace, the **** may pull out.
The complete panel comes out but requires removing a few other panels first.
Might ask at the Toyotanation website.
mahmud335
Feb 6, 2012 11:03 PM
mryang91
Nov 3, 2010 10:52 AM
yulandop
May 27, 2009 09:29 PM
trek
May 31, 2007 02:40 AM
NeoCamry888
Aug 14, 2006 02:11 PM
