A/C controls dimmed
Old Nov 11, 2006 | 06:21 PM
Vic7's Avatar
Default A/C controls dimmed
I have an 01' LE, and have had this problem ever since I got the car two and a half years ago. When I turn on the headlights, all internal instuments are illuminated correctly except for the A/C controls. The right side of the controls are good to go, but the left is really dimmed. At times it'll all be correct, but mostly it's not. Has anyone experienced this, or knows how to fix this problem?
Old Nov 12, 2006 | 02:48 PM
JanSport40's Avatar
Default RE: A/C controls dimmed
My 98 camry did the same thing, I don't how it fixed itself but all I did was hit the side that was not lit and the lights came back on and never did it again, but if you want you can switch out the bulbs which is the hardest thing ever besides taking out the instrument cluster and see if that works out for you. Hope this helps.
Old Nov 12, 2006 | 02:51 PM
Vic7's Avatar
thanks, I'll give them both a try.
Old Nov 14, 2006 | 12:47 AM
boogz's Avatar
i currently am in that situation where my ac lights sometimes are dim or dont come on at all, like JanSport said, i usually hit the side that is not lit up and it comes back on. i guess im just too lazy to change the bulb and see what happens after.
Old Nov 14, 2006 | 02:25 PM
lavalleemike's Avatar
its a loose connection where the bulb goes into the socket usually
Old Nov 14, 2006 | 11:25 PM
Vic7's Avatar
Well, I tried the whole banging the side thing, and it works, but just for the trip. When I get back in the car and restart it, the same problem occurs. I don't know when I'm going to change the bulb, but I will eventually.
Old Nov 15, 2006 | 08:09 PM
JanSport40's Avatar
well glad to hear that it did came back on for a moment. Sounds like my problem with the lights as usual a short probably.
GREENlight
Dec 22, 2019 06:15 AM
nanibabu
Mar 5, 2010 04:53 AM
kbeck79
Sep 18, 2009 04:57 PM
mikec
Aug 6, 2009 06:51 AM
GREENlight
Jul 27, 2009 10:47 PM
