Efi relay getting very hot 1983 2se
Old Jul 3, 2011 | 01:39 AM
johnradfx's Avatar
Default Efi relay getting very hot 1983 2se
had replace fuel pump berore seems now that when it runs it will be okay for say 15 mins then if i wiggle the efi relay it will shut down also the relay is getting ext warm anyone else had this problem.
Old Jul 3, 2011 | 11:28 AM
Might ask at the Toyotanation website in the appropriate forum section.
How warm is warm, can you hold your finger on it with hurting?
The pump is fused and would blow if pulling too much current.
The EFI relay supplies power to the circuit opening relay that supplies power to the pump. If the EFI relay has a bad connection at its socket (perhaps corrosion), wiggling my interrupt power to the other relay and pump.
Check the EFI relay socket terminals for damage or corrosion.
A poor electrical connection can also cause the relay to run hotter.
Old Jul 3, 2011 | 01:03 PM
johnradfx's Avatar
thanks i will check that out otherwise car running okay but def want to solve the shutdown problem.
robE911
Oct 10, 2011 08:30 PM
runner5113
Feb 10, 2011 10:43 PM
johnradfx
May 2, 2010 04:53 PM
Dentfixxer
Feb 9, 2010 07:42 PM
Rayz_Si
Jan 7, 2007 08:27 PM
