1983 toyota camry le 2se engine hard to start warm or hot
Old May 2, 2010 | 01:06 AM
johnradfx's Avatar
Default 1983 toyota camry le 2se engine hard to start warm or hot
have replaced the complete distrubor and still has the warm or hot start issue. so now i am back to the ecu or coolant sensor idea but i am wondering if there is some way to lock this down and solve it i do not want it to die in intersections.
new dist did help and reset timing now feeling its fuel or injector timing that is causing issue as one small burst of start fluid will allow imed restart please help i want to solve this.
Old May 2, 2010 | 11:25 AM
The engines fuel system appears to have a cold start injector system. A single injector that turns on and off to provide extra fuel at engine start. There appears to be a combo coolant temp sensor and timer that controls electrical power to the injector.
It looks like the item at the link below:
http://www.rockauto.com/catalog/moreinfo.php?pk=482472
Perhaps the part has failed.
One place to try to look for info is the Autozone websites vehicle repair guides. You'll need to sign up (free). The site has a great deal of technical repair info for many makes and model of cars.
Old May 2, 2010 | 04:53 PM
johnradfx's Avatar
Default thank you will try that option to
again thanks for info
mikmik
Mar 6, 2013 11:25 AM
johnradfx
Jul 3, 2011 01:03 PM
johnradfx
May 27, 2010 08:29 AM
johnradfx
Apr 4, 2010 10:43 AM
fixitguy63
Mar 28, 2008 07:34 PM
