Engine light is on....OBDII read out is P0401
Old Jul 15, 2011 | 10:13 AM
drwho's Avatar
Default Engine light is on....OBDII read out is P0401
Good Morning Everyone:
I have a 2000 Camry with 108,000 miles. Just changed the Oxygen sensor.
My Engine light is on....OBDII read out is P0401. I have done the following:
1) removed EGR valve and cleaned and honed EGR ports
2) removed modulator top and cleaned out the filter
I have read that the most common problem with this code is the vacuum
switching valve. I followed the vacuum lines from the modulator and EGR
valve and finally found the VSV from underneath. I don't have a hoist...just
got on my back on the street after putting car on the curb. The problem is
I can't get to the 12mm bolt that holds the unit to the block. I can't even see it.
I am just a Saturday/Sunday mechanic. Can anyone help out and give directions as to how to remove that 12mm bolt. Thank you.
Old Sep 28, 2011 | 10:04 PM
AnotherWhiteCamry's Avatar
OK,
Just had a look for the OBDII socket but was unable to locate it.. can someone describe where to find it? I drive a 97 camry with the 3VZ and im in Australia
Thanks guys
Adam
tweakit
Mar 25, 2018 07:20 PM
rkmk836
Aug 16, 2013 02:58 AM
Sugio
Apr 2, 2013 03:17 AM
chong99
Mar 23, 2013 02:44 PM
LetterX
Jul 8, 2010 10:04 PM
