Finally Solved p0500 code 1999 Camry
Old Dec 29, 2021 | 05:25 AM
  #11
ChrisBeatsYoAss's Avatar
Default Similar Issue Resolved
So I bought this 2002 Toyota Solara SLE equipped with the 3.0L V6. I was getting a check engine light for a P0500 code, I swapped out the sensor, cleared the code and went for a drive. Car drove alot better but the code came right back. After about 4 months of dealing with the car either, deciding it doesnt want to shift out of first, going down the road it’ll throw itself into neutral basically “tranny disengages with the flywheel”, or just ROUGH shifting! I decided it was time for this problem to be no more. I honestly was going to go the swap ECU route but I came across this an decided to give it a go. When I tell you that this works, it works! I routed my wires up the strut tower and down into the fender, from there the rubber grommet that holds the wire harness for the door I poked a hole and fished the wires through there and up into the back of my cluster where I spliced and wrapped everything in electrical tape. Make sure you do a nice install from the get go so you dont run into issues and have to disassemble everything. I can take pictures if needed, feel free to message or email me if you have any questions or concerns
Old Apr 26, 2022 | 09:47 PM
  #12
rushmc's Avatar
SWEET! Glad to see my post helped out another Forum member.
DIYDad
Sep 28, 2015 01:32 AM
xpeed
Sep 14, 2014 06:44 PM
b3st0fth3w0rst
Sep 17, 2012 09:55 PM
trdcamrygracia
Jan 11, 2007 09:24 AM
trdcamrygracia
Dec 16, 2005 02:26 PM
