HID KIT INSTALL
Old Mar 14, 2007 | 10:13 PM
JPTILLMAN's Avatar
Default HID KIT INSTALL
DOES ANYONE KNOW WHERE THE WIRE HARNESS IS LOCATED UNDER THE HOOD TO INSTALLED HID KIT?
Old Mar 14, 2007 | 11:19 PM
jasmtz531's Avatar
Default RE: HID KIT INSTALL
What kit did you buy??
Do you want the harness for the headlights or what. Its not a plug and play deal... its a cut, solder, and splice deal. I hope your retrofitting and not just using HID bulbs.
Old Mar 15, 2007 | 11:03 AM
JPTILLMAN's Avatar
IT IS A MCCULLOCH 8000K KIT AND IT IS PLUG AND PLAY BUT I NEED TO KNOW WHERE THE HARNESS IS SO I CAN PLUG INTO IT.
Old Apr 8, 2007 | 03:58 PM
Amoore1011's Avatar
You would have to use th harness that came with the kit. The HID kits are goign to be running off of a seperate wiring harness becuase they need the fuses and the relay so that you can use your stock harness to turn them on...take a look at this pic it should be self explanatory...if not pm me
[IMG]local://upfiles/2110/4E45B5FFC45449CF982D005B044DA7E3.jpg[/IMG]
Old Aug 19, 2007 | 09:36 AM
lownslow23's Avatar
i just installed a 8000k HID kit in my 03 camry...took all of 10 mins GOHID.com
Old Aug 1, 2022 | 07:28 AM
Hathow's Avatar
There is no specific wire harness for installing an HID kit, as the kit will usually come with its own wiring. However, you will need to connect the positive and negative wires from the kit to the corresponding wires on your car's electrical system. The best way to do this is to consult your car's owners manual or a professional mechanic.
Old Aug 1, 2022 | 08:59 PM
And, for the love of god, either retrofit or block the squirrel spotters.
regdawg
Mar 23, 2015 12:45 AM
tooch926
Nov 20, 2011 08:27 PM
imraan77777
Jun 13, 2010 01:59 PM
myCamry05
Nov 8, 2009 10:26 AM
adude247
Dec 15, 2008 07:58 PM
