One-touch Auto Window function
Old Feb 19, 2008 | 04:02 PM
lurchbird's Avatar
Default One-touch Auto Window function
FYI for others who may be come across this in a search...
I took my Camry in to get the remote starter removed (see my other posts). When I got it back, the one-touch auto window button for the driver's window did not function anymore. The fix is simple for this. Simply hold the button down and keep it pressed until the window goes all the way down. Then hold the button up until the window goes all the way up. That's it. Your one-touch auto down and up should now work. Note, you may have to do this a couple of times if the window does not start in the all-the-way-up position, or you stop momentarily at any point. The dealer told me to do this three times, probably as a "just to make sure" measure. As I said, I only needed to do the down-then-up operation once. I believe this is due to the battery being disconnected (at least that is what they said), and the window needs to be re-calibrated. I noticed it after trying to open the window after a freezing rain froze it solid and I had to try about 3 times to open it. Anyway, I hope this helps!
Mark
Old Mar 9, 2008 | 12:34 AM
bossofdakross's Avatar
Default RE: One-touch Auto Window function
Do you, or anyone else here, know if I can get that auto function for the passengers side window too? How about an auto UP function for my existing driver's side control?
gilhouley
Jun 19, 2012 06:21 AM
luzu001
Apr 8, 2009 12:20 PM
