p1135/p1155, HELP!!!
Old Apr 7, 2011 | 04:54 PM
bwjepson's Avatar
Default p1135/p1155, HELP!!!
have a '02 camry with 3.0l having trouble with a/f sensor codes. originally had codes p0141 and p0161, o2 sensor heater ckts. checked sensors and circuits, all test fine. replaced e.c.m. now o2 codes gone, but have a/f heater codes instead (p1135/p1155). have checked circuits and replaced a/f sensors, heater resistance was 4.5-35 ohms. now sensors ohm out correctly, have power through fuse, relay and sensors, to the e.c.m. problem is i still have a/f codes
Old Apr 7, 2011 | 06:58 PM
Might read the post at the link below. It is for an Avalon (upscale Camry) the engine is the same.
2002 Avalon O2 Sensor P1155 Code - Toyota Tundra Forums : Tundra Solutions Forum
Toyota's can have issue with some sensors brands like Bosch. Recommend Denso or Toyota. Don't use a universal sensor.
tournapart
Mar 30, 2022 02:48 PM
ToddS
Mar 26, 2012 07:22 PM
bwjepson
Apr 13, 2011 03:29 PM
kjcho92
Mar 5, 2008 12:32 PM
flyboi
Aug 15, 2007 02:17 PM
