p1135/p1155 codes
Old Apr 7, 2011 | 01:50 PM
bwjepson's Avatar
Default p1135/p1155 codes
i have a problem with upstream o2 sensor heater codes. have replaced sensors, ecm, and wiring all checks out perfectly. have power through fuse, relay, and sensors. also have good wires from sensors back to ecm. that's the entire circuit. any ideas!!!
Old Apr 12, 2011 | 04:31 AM
ambersmith6591's Avatar
What are the specific codes?? Or what year make and model?? If you are getting a code for low voltage to the o2 sensor and also getting codes for a lean mixture, it could have nothing to do with the o2 sesor itself, and could be another problem like a MAF sensor failing.
Old Apr 13, 2011 | 03:29 PM
You can, If you get a DTC for a o2 sensor having low or high voltage, that doesnt mean that the sensor is bad, it means there is something causing the sensor to have low or high voltage. Low voltage means the exhaust is to lean, and high voltage means the exhaust is to rich. Anything that can cause the o2 sensor to go to high or low in voltage will trip the light. Its a B code, so it would take to trips for the light to come on. I need to know what the actual codes are though, the are manufacter specified codes but I wanna be sure.
ToddS
Nov 11, 2019 12:56 PM
bwjepson
Apr 7, 2011 06:58 PM
nj55
Oct 15, 2009 07:16 AM
kjcho92
Mar 5, 2008 12:32 PM
flyboi
Aug 15, 2007 02:17 PM
