radio shows HELP in display
Old Mar 11, 2008 | 07:58 PM
choochoovinnie's Avatar
Default radio shows HELP in display
I changed the battery and apperently this caused the alarm in the radio to arm-I tried the alotted ten times and did not guess the correct code. The owners manual say to contact a dealer. Does anyone have a better idea?
Old Mar 13, 2008 | 11:59 AM
diver1972's Avatar
Default RE: radio shows HELP in display
AFAIK, that would be your only option; however, given enough time, I bet that someone here will chime in with another way of resetting the unit.
I had a Z3 where I had the same problem a couple years ago. I searched through the documentation (e.g. owner's manual, prior owners' notes) and didn't find the code anywhere. I called a local BMW dealership, explained the situation to them, and they advised that I must bring it to a dealership so that they can hook it up to computer to "read/unscramble" the code. It was a no-cost item (besidesmy time to take it there). They read the code and gave it to me. I wrote it down in the owner's manual so that I (and the next owner) would have it for future reference.
Old Mar 13, 2008 | 01:49 PM
Typically only the dealer can reset the code. Some dealers do this for free other charge up to $80.
Typically the code is set by the owner, meaning someone must have set a code into the radio.
In the future make sure the code is not set, you have the code or use a jumper on the battery cables when changing the battey to enable the radio to always have power. Something that is often done.
Old Mar 13, 2008 | 08:17 PM
I went to the dealer and the service manager reset the radio for me. He was nice enough to give ( yes give ) me the sheet with all the codes and instructions on how to reset the radio. ( I was told on the phone it would cost $ 90.00 for them to do it.) Thank you for the replies
Old Mar 14, 2008 | 12:27 PM
diver1972's Avatar
ORIGINAL: choochoovinnie
[sm=bounceybounce.gif]
menno vangrol
Jun 23, 2011 09:28 PM
lsu_guy2002
Dec 6, 2009 11:10 PM
pixshooter
Sep 30, 2009 12:25 AM
mr.niftie
Jul 25, 2009 03:59 PM
Tiger98
Oct 1, 2008 03:39 PM
