Shift lock override button. Please help
I have 95 camry. Everytime I start up my car I have to push the override button up by the shifter to get it to shift out of park. I took the center console out to check to see what could be wrong. Apparently the solenoid or something is bad and isn't moving the plater stopper. Which means I have to use the override button. So how can I fix this?
It could be the switch at the brake pedal. ever since audi 5000's started driving through store fronts, cars are made with a switch that ensures your pressing the brake when you put it intogear.
you should be able to jump solenoid at the gear selector with a 12volt wire to see if it will move when power is applied otherwise check the brake switch.
