Old Sep 1, 2015, 03:53 PM
How-Tos on this Topic
Browse all: Engine Guides
Print Wikipost
1997 camry 2.2 engine knock
Old Dec 15, 2011 | 04:56 PM
dorfmon2's Avatar
Default 1997 camry 2.2 engine knock
my daughters car, driven across state regularly. has 118,000 on the clock. started rapping deep in the engine but only at lower rpm's (stops just before normal shift points). i lent her my extra truck while i'm checking it out. disassembled to check oil pump (seems good) and was going to survey rod and main bearings but discovered that the big ends of both balancer shafts below the crank have very noticable play and may very well be the source of all the noise. anyone have any experience with this assembly? manual says DO NOT open, send to repair facility. thanks for any help
Old Dec 15, 2011 | 08:50 PM
Excessive gear backlash can cause knocking similar to a rod knock.
The shafts are shimmed to obtain the correct gear backlash.
The Toyota manual has the procedure for checking backlash but it is complicated and requires a dial indicator or similar to measure it.
If your up to the task send a private message with email address for the procedure info.
It is not uncommon for owners to take off or not reinstall during rebuild the balance shafts. Not all 5SFE engines have them, depends on the model of car.
If you go this route you need to plug up the oil feed holes.
A search at the Toyotanation website on removing the balance shafts should produce lots of good info.
Old Dec 21, 2011 | 09:00 AM
andersongreen's Avatar
read the post it great to see that posts and that's an good job guys.
Old Oct 25, 2012 | 02:00 PM
yasukiaichi's Avatar
I know a place that sells low mileage Toyota Camry engines. Check this out Used Toyota Engines & Motors | Toyota Camry, Corolla, Celica, 4Runner, Highlander engines from Japan...
Their Google plus page is: https://plus.google.com/b/1004590206...36680236/about
PredatoryTrep
May 23, 2010 08:32 PM
phundoo
Sep 30, 2009 07:16 PM
bullyd
Mar 9, 2009 06:47 PM
mirro79
Feb 25, 2009 04:22 PM
bfaidherbe
Jul 7, 2006 10:59 PM
