2004 Camry LE 2.4 cyl
So, this problem have been going on in a while.
I have no problems with my car..but a minor thing that is really annoying is that, when I turn on my car there is a squealing noise coming, I thought it would be the timing belt slipping or something but i talked to my friend today, he thinks it is the tension bearing needing to be replaced.
I currently have 56k miles on my car, and its been squealing, mostly when its cold.
Anyone experiencing this or know how to fix it?
Thanks
Thanks
Have you checked the assy belts, one could be loose?
There is also a hydraulic damper that keeps the assy belt tight. It can go bad and cause a loose belt. Or could be the bearing you describe.
roland13
Sep 1, 2019 11:02 AM
