2JZ-GTTE swap
I have a 1995 camry LE wit the 2.2L and it has a lot of miles on it and i want something with some power. Would the 2JZ-GTTE motor and if not do you have any other engines in mind that mite work?
Thanks
Ted
Thanks
Ted
The link below has info on this engine. It will bolt up to the engine. The 3S-FE was used in Camry before the larger 5S-FE and should fit into the Camry.
http://www.toyotacelicaonline.com/celica1/3sgteswap.htm
You will need another computer, harness, etc.
Alrite sorry about all of this. One last question cause i just want to make this as easy as I can. Would a 94-96 1MZ-FE V6 and auto trans fit in with no real big adjustments needed? And if so what things would I need to do?
SymtecX
Feb 27, 2006 03:16 AM
