3L & 3.3L differences
Old Feb 26, 2012 | 07:48 AM
1stackmack's Avatar
Default 3L & 3.3L differences
What's the difference between the 3.3 liter & 3.0 liter engines? IS IT THE CAM, CAM TIMING, BORE & STROKE? I'm thinking of buying 2005 camry; research tells me there is 2 different size V6 motors for that year. Dont want to get stuck with a lemon. Any info would be appreciated. 1stackmack.
Old Feb 26, 2012 | 09:23 AM
The 3.3L might be called a larger version of the 3.0L. The 3.3L has a larger bore, same stroke, different cam profiles, slightly higher compression, higher HP, more torque at a much lower engine RPM, engines are about the same weight.
The 3.3L has been used in many Toyota products but only offered in Camry for a few years.
If your looking for max HP and torque then go with the 3.3L.
inredding
May 30, 2015 09:34 PM
Winfield1990
May 18, 2010 04:58 PM
hank1
Feb 17, 2009 06:20 PM
Cjsredpra
Jun 25, 2008 06:00 PM
Blutie
Aug 18, 2007 05:22 AM
