'89 Camry 4 cyl - Spuddering
So I just had a new thermostat/timing belt/water pump/pulley/tensioner done last week. I took the camry out of power mode at a stop light and it started spuddering when I hit the gas as the light turned green. I switched it back and forth and put some new gas in it but I doesn't seem to help yet.
The car seems to regain some power and consistency in running at higher speeds/rpms. I hasn't stalled on me when it's idling but it gets close.
I new suggestions please! Vacuum? Fuel filter/sensor?
Did the engine run OK before the work was done? If so, could be a vacuum hose or ign wire was not installed correctly after the repairs.
If it ran the same check the ign system, coil, rotor, cap, ign wires, plugs, etc.
smilands
Jun 15, 2006 04:38 AM
lavalleemike
May 9, 2006 02:34 PM
